It is currently Thu Sep 18, 2025 9:10 am
 Post subject: spindle sander
PostPosted: Wed Feb 10, 2021 6:01 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Does anyone use those hand held spindle sanders (for a drill) to sand sides? If so what is the brand and size
Mike McNerney
 Post subject: Re: spindle sander
PostPosted: Wed Feb 10, 2021 6:22 pm
First name: Toonces
Last Name: the Cat
City: New Smyrna Beach
State: FL
Unless you dabble in metalwork -- just get the Chris Ensor "Elevate" tool. There is also a recent thread about this - try searching for it in the archives as it got quite a few responses and helpful tips/advice for using them.
PostPosted: Wed Feb 10, 2021 7:27 pm
Chris Paulick makes some nice ones. You could do the same as he has some good youtube videos showing how he makes his rolling pin sanders.
PostPosted: Wed Feb 10, 2021 8:02 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I made a nice rolling pin sander using two of the rubber drill press sanding drums end to end, some all thread, some nuts and washers, a handful of bearings (all shoved together to make the handle), and matching long sanding sleeves. It works great. However, I had to McGyver that sucker together. You might as well just buy one from Elevate and save some time.
PostPosted: Thu Feb 11, 2021 7:55 am
Last Name: Ball
I got mine from Grizzly, a Shop Fox branded one. They sell two sizes, I use the smaller one. I don't use it on sides, but do use it on heels.
PostPosted: Thu Feb 11, 2021 10:24 am
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
The Grizzly sanders are (carefully!) inflatable and conform to curved surfaces very nicely without cutting facets into the work. I used my small version to help shape a neck. I saved hours of hand sanding. Also helps to know when to stop.
Peter Havriluk
PostPosted: Thu Feb 11, 2021 12:07 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Thanks all. The Elevate stuff is fantastic, and I might just get the sander and binding jig. I'think I'll try the fox one for necks first. Mike
Mike McNerney
PostPosted: Thu Feb 11, 2021 1:05 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
Been using a grizzly for a couple of years mostly on sides. I'm shaping a couple of necks now. Thanks for reminding me to break it out. I've only found sleeves to fit it at grizzly. Kinda pricey but they seem to last a long time.
PostPosted: Thu Feb 11, 2021 1:23 pm
I have the elevate one and it is really a great tool. Can’t imagine why I wouldn’t want it
PostPosted: Thu Feb 11, 2021 2:16 pm
City: U.P.
This thread reminded me I needed some new sleeves. I bought a 1 1/8 pneumatic sander from Woodworker's Supply a few years ago and love it for neck work, cuts a lot of time off end grain sanding on the heel and transition to peg head.
Looking around for soft sleeves I came across this -- https://toolsandmore.us/woodstock-d4623-soft-sleeve.aspx
They also had the 1 1/8 rolling pin for $65, best deal I've seen on those too and the sleeves were a decent price too. If anyone is interested.
I never tried it on sides and was curious if anyone with a pneumatic rig with a larger dia drum, like https://toolsandmore.us/shop-fox-d4595-pneumatic-drum-sander.aspx has tried it on sides?
OR, is a solid drum better for that? I can see advantages to solid in it being straight, but downside would be sanding divots more readily if you weren't really careful.
I've had solid rubber drums that mount in the drill press but the ones I've had never seemed to center the sleeve on the arbor axis so they were not too good for accurate sanding.
For folks using the Elevate tool, How well does the drum center on the drive line center?
Thanks in advance.
Brian R, Wood Mechanic
N8ZED
PostPosted: Thu Feb 11, 2021 6:06 pm
First name: Carl
City: Forest Ranch
The 2 1/4" is the one I have and use it primarily on sides. Been using an 80 grit sleeve. Clamp the body in a holder and work your way around a little at a time. Be ginger with it until you get a feel about how much material is coming off. Each wood type seems to sand differently. I try to sand the side to the binding so the binding width stays the same all the way around.
Grizzly has many more sleeve grits available than toolsandmore. Cheaper too.
PostPosted: Thu Feb 11, 2021 6:14 pm
Last Name: Ball
I saw a thread somewhere out in cyberspace where a fellow with a new Martin measured side thickness at about 1/32" thick around the waist. Overzealous sanding at the factory no doubt. But power sanding sides still scares me because of stories like that. I rout my binding recesses to where there's very very little material to be removed to level up with the sides. A card scraper does the trick for me...
PostPosted: Thu Feb 11, 2021 6:31 pm
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Yes that is an interesting note. over the years as a cabinetmaker I have done a lot of veneer work. In 1983 I did a BRW credenza with .025 veneer. The guy who laid it up for me, sanded the veneer tape off with an 80 grit belt on a stroke sander. He was unbelievably fast, but did not sand through anywhere. When I started the edge banding my helper sanded through in a couple of places and I had to inlay some areas. The guitar bodies I am working on now are laminated sides with a .025 show veneer. I can see with a rolling pin sander when working on the sides I will have to be focused but somehow I'm not that worried
Mike McNerney
PostPosted: Thu Feb 11, 2021 6:41 pm
Last Name: Ball
I have nothing at all against power tools, and use them a lot in my shop. But I like to use them for the roughing out phase of things--my old bones can only do so much, and I like to save them for the fun stuff, and the stuff where handwork really makes the difference.
Users browsing this forum: johnparchem and 37 guests
